Thread Tools Rating: Thread Rating: 9 votes, 4.22 average. Display Modes
Old 01-09-2024, 10:42 AM #181
mbumpus11's Avatar
mbumpus11 mbumpus11 is offline
Real Name: Bump
mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about
mbumpus11's Avatar
Real Name: Bump
Originally Posted by MCinKC View Post
Are you talking the cable from the actuator to the door? Or a rod from the handle itself. Appears to be a metal rod from the handle that is not connected to something in the door.
Just to clarify, I am having issues with the outside handle. Interior handle works just fine.
Did you get the outdoor handle working again? A couple posts above I had made a note of what to do under the "***EDIT***" segment of the post to make sure you get that physical rod back in the right spot for the ext handle. I had the same issue with interior/electrical locks/door working, but the handle wouldn't open from the outside.
Let us know!
2015 Magnetic Gray Trail Premium - Build Thread: https://www.toyota-4runner.org/5th-g...ight=mbumpus11 <<<--- click that to see what I've done
mbumpus11 is offline   Reply With QuoteReply With Quote
Old 01-11-2024, 04:18 PM #182
ssgcmwatson ssgcmwatson is offline
ssgcmwatson is on a distinguished road
Thanks - mine went out recently and this is very helpful!
ssgcmwatson is offline   Reply With QuoteReply With Quote
Old 04-27-2024, 06:52 PM #183
rjb75 rjb75 is offline
rjb75 is on a distinguished road
Just changed mine today-the write up is spot on. Instead of trying to get the door lock cylinder rod aligned properly, I made sure the rod for the outside handle was in properly and removed the lock cylinder to align it once everything else was back together. Made it very straight forward.
'16 SR5 Magnetic Gray Metallic
rjb75 is offline   Reply With QuoteReply With Quote
Old 05-29-2024, 01:11 PM #184
kirbyyy86 kirbyyy86 is offline
kirbyyy86 is on a distinguished road
I'm so appreciative of this post- I was quoted nearly $750 to replace my driver's side actuator. My question is this- it seems to not be "dead". When I press the lock button on the remote, the door makes a noise that sounds like a buzzing duck, for lack of better descriptive. Like the motor is working but just not connecting, instead of the part being no good.
It started when I was locked inside my own car, unable to open the door from the inside, and then unable to lock even with a key. Now after some force, I can lock using the manual slider near the door handle, as well as with the physical key in the exterior door. It just buzzes/grinds when I hit the windowsill button or the remote. Does anyone have any ideas as to what my first step would be to investigate further?
kirbyyy86 is offline   Reply With QuoteReply With Quote
Old 06-01-2024, 11:31 AM #185
mbumpus11's Avatar
Real Name: Bump
mbumpus11's Avatar
Real Name: Bump
This sound you describe is common before the motor fully dies. If it makes noise when using the button/key fob but isn't powering the lock/unlock, your motor needs to be replaced. What you're likely hearing is the whine of the motor internals attempting to turn the spindle which in turn moves the cables/locks. I don't know for certain, but I don't think you're at risk of any serious damage, just the inconvenience of having to manually lock/unlock once it does officially go kaput.
My main question regarding the "force" part is if you have any issues with the actual handle itself? Hopefully not, as those are sheathed cables inside the door cavity just like the cables for the lock mechs. If that is an issue, have you had any problems with your window rolling down/staying down? Sounds like there could be a physical obstruction which would likely be discoverable by using the first part of this thread to remove the plastic interior door covering (it comes off pretty easy, shockingly easy for some).
Let us know your finding!
4runner , 5th gen , actuator , actuator motor , door lock
Door Lock Issues: Actuator or just Lock Motor replacement Mlynn 4th Gen T4Rs 15 02-01-2022 09:17 PM
Fuel tank removal step by step, DIY w/pics the great him 3rd gen T4Rs 17 02-15-2021 02:41 AM
Door lock actuator motor Jason11 3rd gen T4Rs 13 08-25-2018 02:29 PM
WTB: Front Driver side door lock actuator Golfinz For Sale: T4R Items 4 02-08-2013 10:21 PM
Driver Side Door Lock (Actuator?) streeter 3rd gen T4Rs 4 09-23-2012 07:53 PM
